Introductory Materials > Input and Output Data Buffer Architecture
Analog In Word
All instruments may write data to the input buffer from analog input signals or from the digital input port. Similarly, data contained in the output buffer may be written to the DAC or to the digital output port on DI-200 Series instruments; or to either DAC (DAC1 or DAC2) or to the digital output port on DI-400 Series, DI-500 Series, DI- 720, and DI-730 instruments (DI-401 and DI-700 instruments do not support output operations, therefore there is no output buffer). The following describes the format of any word appearing in the input or output buffer. These data word formats assume that only the SDK is running. If WINDAQ software is running in conjunction with the SDK, Y1 and Y0 are undefined. Because DI-200 Series instruments have only one I/O port, both DMA data and control information (i.e., commands, status, etc.) must share this single port. Therefore, in order to distinguish the word as DMA data (as opposed to control information), the two LSB's of the data word must be zero.
Analog In Word
All 12-bit instruments (DI-200, DI-400, DI-401, and DI-500 Series) with signal averaging off, or DI-220, DI- 221TC, and DI-222 always (regardless of signal averaging)
D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0
MSB data data data data data data data data data data LSB 0 0 Y1* Y0*
D=indicated digital I/O line; *If you are looking at the first channel in the scan list, Y1 reflects the inverted state of the remote start/stop flag and Y0 reflects the inverted state of the event marker flag. Otherwise, Y1 and Y0 are zero. If analog data is a unipolar signal, the number is a straight binary value. Bipolar signals are in 2's complement format.
All 12-bit instruments (DI-200, DI-400, DI-401, and DI-500 Series) with signal averaging on, or all 14-bit instruments (DI-210, DI-410, DI-700, DI-720 and DI-730)
MSB data data data data data data data data data data data data LSB Y1* Y0*
All 16-bit instruments (DI-700, DI-720, and DI-730)
MSB data data data data data data data data data data data data data data LSB
D=indicated digital I/O line; If analog data is a unipolar signal, the number is a straight binary value. Bipolar signals are in 2's complement format.
Analog Out Word
All instruments that have analog output capability.
MSB data data data data data data data data data data LSB R R 0 0
D=indicated digital I/O line; If analog data is a unipolar signal, the number is a straight binary value. Bipolar signals are in 2's complement format. R=reserved.
Digital In Word
All Instruments Supporting Digital In
D7 D6 D5 D4 D3 D2 D1 D0 X X X X X X Y1* Y0*
D=indicated digital I/O line; X=ignore; *If you are looking at the first channel in the scan list, Y1 reflects the inverted state of the remote start/stop flag and Y0 reflects the inverted state of the event marker flag. Otherwise, Y1 and Y0 are zero.
Digital Out Word
All Instruments supporting Digital Out
D7 D6 D5 D4 D3 D2 D1 D0 X X X X X X 0 0
D=indicated digital I/O line; X=ignore.
A/D Coding
A/D Input Coding A/D Output (Hex)**
12-bit 14-bit 16-bit
+FS Unipolar* 7FF0 7FFC 7FFF
1/2 FS 0 0 0
0 -8000 -8000 -8000
+FS Bipolar 7FF0 7FFC 7FFF
0 0 0 0
-FS -8000 -8000 -8000
FS = full scale; *DI-221TC, DI-400 Series, DI-500 Series, DI-700, DI- 720, DI-730, and DI-5001 instruments do not support unipolar operation. **All data is left-justified, with extraneous bits (if any) equal to zero.
